Willispwillis
Good day my 150 faststrike runs great but doesn't want to idle down as of this past Saturday. I did some digging and found the white ground procedure to kick the cold start off it did change the idle very little on muffs I had the boat at home when I decided to check it but early that day the tach was reading 1200 give or take a 100 rpm in forward in water. I have been trying nail down a stator or regulator issue so the engine covers have been off but nothing other then probing wires and checking connections has been done. My return spring isn't broke and it will not drop rpms with adjusting the low idle lever all the way to the minus side. The roller on the arm isn't missing and the throttle arm isn't contacting the roller when at low idle and all the butterflies appears to be closed any ideas would be appreciated thanks again have a good one yall.
