proline 34
To recap, I had a bad switch on my controller for the stbd side tilt/trim. I ran two new wires from helm controller (from blue green at helm to blue green on engine) to tilt motor wires on engine and now tilt motor works fine. Stbd engine ran fine a week ago, but now when I turn key at helm, there is nothing. Fuel gauge does not move, tach does not light, and alarm does not sound. Port engine works fine. I thought it might be ignition switch, so I swapped the stbd ignition switch for the port and the port still started up fine with nothing on stbd side.
I checked the fuses and the fuses are fine. I checked continuity and power through the fuses and all good. I have power from battery to bolts on starter. still nothing on starter. still nothing.
In addition, under helm panel with gauges (tachs and fuel) Found a double female pigtail (double green wire) coming out of starboard tach with no male plug anywhere. Cannot find an unassigned male anywhere. Could this have anything to do with this?
I'm at a loss. I checked all wires and they are all connected, i checked all harnesses.
Any ideas what I may be missing?
