Hi all,
I have a 1990 25hp outboard and am having issues with getting rpms beyond 4000. Everything says it should be running around 5000-5500 at WOT. The engine runs perfectly. Starts a tiny bit hard and sneezes a couple of times when cold, but other than that runs fine through the throttle range...it just won't make more RPM. Throttle linkage is correct when the throttle is wide open, so I'm a bit stumped. The prop is new, but the same pitch and diameter as stock (I don't remember what it is off the top of my head) I've tried pitching the motor up a notch (it's manual trim) and that made no difference except to slow down takeoff speed. Any ideas?
