powerplay38
I noticed that a corner on my intake gasket was popping out so I bought a new gasket kit from my local mercury dealer and changed the gasket. I didn't use the rubber gaskets on the front and back of the engine. I used the recommended gasket silicone that the mechanic told me about. I replaced the gasket set and let the engine sit over night before I started it up so the silicone had time to set up. the next morning I hooked it up to the ear mind muffs and it started right up, I timed it back to 8°. idled it back down to 650 rpm. temperature at about 160 or so. after it ran for about half an hour I shut her down so I could change the oil. I drained the oil and replaced filter and new sae40 oil. when I started it back up, the temperature was running hot quick. 200-220. I shut it down immediately. I had recently replaced the impeller and housing in the outdrive too because I was sitting in mud for a while at the marina last year. had a bunch of zebra mussels on the bottom of the boat and outdrive. I'm shooting a good spray of water out of my exhaust when it's running also. I think I gave you guys as much information as I know of. now with all that info can anyone give me any ideas about what the hell is going on here with this engine?
