This pretty much sums it up.If voltage is getting to the solenoid when the toggle switch is pressed to the choke position, and the solenoid is not activating, then the solenoid is the problem. Or its ground.
If voltage is not getting to the solenoid when the toggle switch is pressed to the choke position, then the switch is faulty.
