dsharretts
Hi,
Hoping I can get some hints on a problem I've been struggling with. It seems I've got a short to ground on my black/yellow Kill wire(s).
Motor starts and runs with black/yellow wires disconnected at power packs.
Motor starts and runs with red controls connector disconnected and kills when reconnected.
No spark with black/yellow wires disconnected from ignition switch. This is a new OEM ignition switch - replaced this (and lanyard switch) first, same issue as I had with original switch.
So this leads me to believe I may have a short to ground between the Controls and the motor. However, I've tested with a meter at the red connector as well as at the black/yellow connectors running to the power packs (both running and off) and I get NO ohms reading that would indicate a short.
Seems to me if I have a short I should be able to see that with the meter. Just trying to verify before I read all the wiring out for nothing.
Thanks for any help.
