The OB is a E30RLC0A. How do you start the motor, how many pumps on the primer?
Next the foam insulation on the top cover has degraded. What is a good replacement? Do I really need it?
Man the water pump is a pain to rebuild, not really but the reassembly is a pain with the long shaft, long water tube, and the copper tube.
I sure would like to find an Owner's Manual for it.
I do have a Shop Manual.
I have it on a 17' MirroCraft aluminum open boat. When It was running (last running 2017) It would do almost 30 MPH. I bought it used from a Fire Department Near Healdsburg, CA in 2008ish.
Thanks Glen.
I'm in Idaho near Boise.
Also would like to install an Electric Starter.
Yes I use 50 to 1 mix...
Thanks Glen.
