I have seen quite a few threads related to this problem. I have a fuel oil mix leaking out from under the upper exhaust housing. Engine seems to be running good and starts fine. The leak is significant enough to be visible in the water. Ironically, the fuel recirculating hoses were leaking and not installed correctly, now that they are routed right and connected to the nipple to lubricate the main shaft bearing the leaking out the exhaust directly below the engine seems to be worse. I realize that this will take some tearing into to isolate but any insight on what appears to be a common problem on older two strokes. Exhaust related gaskets or Main shaft seal maybe?
Thanks, MitchB
Thanks, MitchB
