Hi all,
I have a J175TLCTD, a 1983 Johnson V6 175hp. I am running into an issue not being able to turn the engine over because it won't build fuel pressure when pumping the priming bulb. Initially I thought it was a stuck float needle in the carb bowl because I saw fuel running out of the carb throat when pumping the bulb. I removed the carb and replaced the float and needle to find that it was still leaking. I found that the fuel is getting past the primer solenoid when pumping the priming bulb, the red lever is parallel to the solenoid body in the "normal" run position. Could fuel getting past the primer solenoid be the cause of a lack of fuel pressure when pumping the priming bulb? How would I fix that?
