tickridge1212
I have been doing some research on the internet and ran across this forum. It looks like a great place! I have just registered and I am posting my first topic. Hopefully you all can help me out on a couple questions that I have. I am replacing some gaskets in the midsection (exhaust housing) of a 1982 Evinrude 50hp long shaft and have encountered a couple of problems. I am scared to finish reassembling the outboard without knowing the answers.
1) I have read some conflicting information on the internet concerning the new replacement gaskets that are now available. I have purchased a new powerhead to adapter gasket and an adapter to midsection gasket. I have the original shop manual and it says to use gasket adhesive for this year and model. I have read that the newer gaskets that appear shiny and are somewhat sticky do not require the gasket adhesive. The gaskets I have match that description. Should I still use adhesive or leave them alone?
2) The water tube grommet that goes between the top of the water tube and the adapter plate needs to be replaced. The original soft rubber grommet has been discontinued (322308) and replaced by a hard plastic water tube washer (332363). The original grommet fit snuggly and filled the entire area between the water tube, adapter and flange that clamps the tube to the adapter plate. The new replacement washer does not fill this area completely. I am concerned that there may need to be two washers (one on each side of the flared end of the water tube. It seems like this washer will cause water to leak at this location. Has anyone used this new washer instead of the grommet? Any advise on this one?
Hopefully I have provided enough detail for someone to understand what my concerns are. thank you very much in advance for any help you can provide.
