Jacques Elias
My Johnson will start right up using the fast start lever. It idles fine when the lever is up or even when I turn it on. When i move the fast start lever down it idles ok but spuders a little. No matter how long I let it warm up the engine will shut off once I put it in heat. If I get the rpms high with the fast start lever and put the boat into gear as the rpms come down the boat will run into gear. Any idea what the problem might be? Thanks.
