[FONT="]1979 Evinrude 35 hp model 35952A (Commercial) with a console/cable steering and throttle.[/FONT]
[FONT="]
[/FONT]
[FONT="]So...removed the lower unit to repair the water pump. Once that was complete, the LU was reinstalled. Upon testing the new water pump (with muffs...successful repair), I was shifting it in and out of forward, neutral and reverse. Forward was awesome, neutral was no spin, and there is no reverse. Dang it! [/FONT]
[FONT="]
[/FONT]
[FONT="]I should say that prior to removing the LU for the water pump repair, everything shifted properly and had forward and reverse.[/FONT]
[FONT="]
[/FONT]
[FONT="]Removed the LU, adjusted the shift rod to where the prop spun freely in both directions and the drive shaft was not spinning. Went back to the controller, made sure the shift handle was in neutral also. Reinstalled the LU...same thing...no reverse.[/FONT]
[FONT="]
[/FONT]
[FONT="]Went to the shift adjuster and tinkered with it, loosening and tightening, still no luck.[/FONT]
[FONT="]Removed the shift cable from the linkage on the starboard side of the motor and, with the motor running, moved the shifter by hand.[/FONT]
[FONT="]
[/FONT]
[FONT="]Wiggled it to make sure it was in neutral, and moved it into forward...moved very easily and the prop started spinning.[/FONT]
[FONT="]
[/FONT]
[FONT="]Went back to neutral, prop stopped spinning. Moved it into reverse, and it was very hard to move. I could feel the gears trying to engage...kind of thumping or pulsing came through the shift handle. Pushed a little harder towards the rear and the gears engaged and prop started spinning in reverse. Didn't feel right so I went back to neutral and shut it off. And then I came in here to type this question.[/FONT]
[FONT="]
[/FONT]
[FONT="]Any help would be greatly appreciated. I feel like it is close to being right...just not sure what to adjust. [/FONT]
[FONT="]
Thanks,[/FONT]
[FONT="]
[/FONT]
[FONT="]Brandon[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[FONT="]
Thanks,[/FONT]
[FONT="]
[/FONT]
