I picked up this motor and was told it had problems running. First checked compression and was 90 and 92. Figure it should run with that and checked spark with tester and that would make the jump so all good so far. I put it in my water barrel and got it started and was pumping good but had to choke it to keep it running so did the carb and all was good with it now. Put it back in the barrel and same thing so decided to pull the plugs and they were wet with greyish water and kind of foamy. Figured head gasket and pulled the head and the gasket to my eyes looked fine and could not see where it would have been leaking so my question is there any place else water could be getting into the cylinders? Was told it was fresh mixed gas about 2 weeks old when I picked up the motor so figured it was fine. If no place else for water to get in I feel I may have made a mistake using that fuel.
