Hi guys,
Wondering if you can assist?
I have a twin engine 55hp evinrude 1977 setup. No spark on either cylinders with the black/yellow connected, spark is good with the kill wire disconnected.
Wiring loom from working engine, was put on the not the not working engine and engine fired once this morning, after this we were unable to get it firing and had no spark. By swapping the loom between engines, we believe we don’t have any wiring issues within the loom, nor issues at the switch, it would appears as though there may be a short to the black/yellow wire, within the motor wiring itself, is this possible? Is there anything you may know I should be looking for or some sort of test to help identify the issue whih appear to be at the motor..?!
Thanks in advance
Thanks in advance
