Jhollenbeck
I am in the process of rebuilding a 1968 Mercury 39, at this point I have rebuilt the water pump, new fuel lines and pump disphrams, cleaned and rebuilt the carb and new lower gear oil. I am able to get the motor running with starter fluid, it does not idle for long but if I throw it in forward it stays run. I have a few general questions to understand more about this motor and how much better this old technology will run.
1. Should the water pump be pushing water through when I am in neutral? I do not have water flow unless I have it in gear, trying to determine if this is the design of the motor or if there is issue with the water pump.
2. Should I be able to start the motor without using starter fluid? If this were 1968 I would assume you wouldn't need to use starter fluid to fire it up but is there issues if I need starter fluid everytime I want to start it up now?
3. I was told by the previous owner that it never idled well, is there something I can do to correct that or is that a limitation of this motor?
