Jerry12302
I have a 1965 Starcraft I inherited, wiring is a mess.
This is probably a stupid question, but I would like to run new wiring from the battery to the dash. Do I need a separate hot wire from the pos terminal to every switch? I have 2 light switches, a horn, and the trim motor switch. Can I jump the hot from one switch to the other under the dash? Is that parallel wiring? What about in line fuses?
The ignition is separate, and works fine, not touching that.
