I picked this motor up real cheap and was taking it apart to clean and to replace the impeller. I removed the powerhead and found a cork washer and a ss washer was stuck to the bottom of the crankcase. On top of the drive shaft I found what appears to be a ss bearing followed by a small O ring which fits inside a black seal, a spring, and a washer that the spring fits into on bottom. I can't find this ss bearing anywhere in the parts manual. I know someone had taken this motor apart previously as there were some parts missing. I'm attaching photos showing the bearing in question (marked with a green arrow). If anyone can help identify this part, I would appreciate it.
Thank you.
- Bob
Thank you.
- Bob
