1994-2006 as these are 113 CID blocks and the early 1988-1993 are 105 CID blocks. You can use any hp from 100-125 hp of these years (94-06) ......
that is correct....so correct me if im wrong, your saying 94-06 is the same block
Yes you could but being a smaller bore you would have to purchase different pistons,wrist pin bearings, and rods as the 105CID are bottom guided and the 113 CID are top guided..but I could also use anything back to 88 if I had to?
