snowhound9
"I have a 2007 5.7 OSi-GF. Th
"I have a 2007 5.7 OSi-GF. The power steering has worked fine through 100 hours. Ran the boat yesterday, and steering is very "hard", almost like the power steering isn't working. I also no longer hear the "hiss" of the power steering pump. The appears to be plenty of fluid in the reservoir. The "only" things that have changed since the last run (where it worked perfectly) was that the fuel cell was changed (both fuel pumps + fuel filter assembly), and the oil was changed. Also, if I look in the reservoir after running, the fluid is frothy - there is a lot of air in it. Is there anything I can do, or is this another warranty issue?
Also - stupid question for a new Volvo I/O owner - should the exhaust be exhausted through the center of the props when the boat is sitting in neutral at idle, or at the top of the head?
Thanks,
Mark"
Thanks,
Mark"
