crownroyal
" My 1988 Johnson 60 hp has be
" My 1988 Johnson 60 hp has been rebuilt. Compression in all 3 cylinders are 140. All 3 carbs have been rebuilt twice,never found any trash or gunk in jets or bodies.Lync and sync is right and the timing is set right.Pump bulb stays hard and there is no gas leaks or air leaks.No trash in gas tank and have fresh gas with oil mixture(vro pump disconnected couple yrs ago). The problem thats driving me crazy is the engine will start and idle just fine. You can rev it up with the warm up lever and it revs as high as you want to go.When you put it in gear is when the problem starts. It bogs like its out of gas ,push the key swith in a couple times and it runs like a new motor. It will run wide open throttle all day long with no misses or bogging down. Seems when youre running wide open throttle and put it in neutral ,wait a few seconds and give it WOT it takes off just fine. But,when you stop and fish for a while with engine off and start back up,itll start fine but when put into gear it bogs. The bulb is hard but it still seems like a fuel starvation problem. Any suggestions would be helpful. All i can think of is the fuel pump(but id think it would miss or not get full rpms if it was fuel pump or it could be the valve the 3rd like from fuel pump goes to(maybe its bad) . Got me puzzled "
