L
Lee Herring
Guest
" My motor loses rpm's aft
" My motor loses rpm's after about 15 minutes of riding. Sometimes it will straigthen up after it sets and sometimes it won't. It only turns about 1500 rpm's at full throttle. Ignition boxes are new, ignition coils are new, spark plugs are new, Have drained the gas tank and it's clean, have cleaned all three carbs. number three had some water in it but now it is clean, I unhooked the temp sensor to see if it was cutting out due to heat and it didn't change, I'm running out of ideas. There is a small hose coming off of the intake under the bottom carb. It is not hooked up to anything and it can suck air in through it even water if it gets to it. Where should this hose be going to? Also are there any ideas on the rest of the problems I am having with this motor? The engine runs smooth even though it will not rev up after this takes effect. It idles good and has a very strong spark. Could my lower unit be seizing up causing it to lose rpm's? "
