Results 1 to 5 of 5
  1. #1
    Default " Hello...I have a couple of q
    " Hello...I have a couple of questions on installing a new water pump repair kit on my 90hp Johnson. I picked up a book from the library and even though it's very informative it doesn't answer everything. I have a 1987 or 1988 V90. One question I have is about removing the gearcase. It says to remove the trim tab screw which I have. Then it says to remove the countersunk 5/8 in screw between the trim tab cavity and gearcase housing using a narrow wall socket, and it shows a picture. The problem is in the picture it shows only one screw (bolt) and there are actually 2 and nothing is said about the second screw. Then it goes on to say remove the screw from inside the trim tab cavity (if used) with a 1/2 in. socket and extension and it shows a picture of that also. I guess my question is do I remove both the screws that are located just ahead of the trim tab or do I remove just one and if so which one? My next question is what is the reason for removing the shift rod retaining clip, is it so the shift rod will come off with the gear case? I'm sure I'll have more questions as I get further into this project but that's all for now. Thanks Bob "
  2. #2
    Join Date
    Feb 2001
    Location
    Central West Florida
    Posts
    14,308
    Default " The shift rod is attached &#
    " The shift rod is attached (threaded) to the lower unit. The adjustment of that rod is critical so do not distrub it.
    If one of those bolts is going through a "zink anode", there is no need to remove that bolt. However, remove the other bolts.
    Joe "
    We occasionally have questions. If you fail to answer, it may affect ours.
  3. #3
    Default " Joe you are right I hadn'
    " Joe you are right I hadn't noticed the bolt went into the "zink anode" I went out and looked again and noticed above it was a "zink anode" that the bolt screwed into. So, on the shift rod should I remove the retaining clip so the shift rod will come off with the gear case and then make sure I don't screw the shift rod in or out once the gear case is off or will I be able to get the gear case off if I don't remove the retaining clip? Thanks...Bob "
  4. #4
    Default You remove the clip and push
    You remove the clip and push the assembly in to disconnect the shiftrod.
  5. #5
    Default Just wanted to add that the b
    Just wanted to add that the book/manual I got from the library said to put the shifter into reverse at the start. The problem I ran into was that with it in reverse and after pulling the retaining clip on the shifting arm there is no way I could push the shifting unit over to get the pin out of the shift rod so it would drop down. Finally had to put it into neutral and then was able to push the unit over far enough to get the pin out of the shift rod so it would drop down. I hope this bit of information helps someone else. This is a great site thanks for the help I have already learned a lot just from reading the other posts.
    Bob
Similar Threads
  1. Water Pump amp Lower Unit 1990 90hp Johnson
    By ixolib in forum Johnson Evinrude Outboard Archive
    Last Post: 05-17-2008, 01:10 AM
  2. JOHNSON 90HP 1982 WATER PUMP
    By A. WEISE in forum Johnson Evinrude Outboard Archive
    Last Post: 11-24-2007, 08:32 AM
  3. JOHNSON 90HP 1982 WATER PUMP
    Last Post: 11-24-2007, 06:43 AM
  4. 25 Johnson water pump repair on 1999 model
    By jnrmond in forum Johnson Evinrude Outboard Archive
    Last Post: 05-30-2007, 04:56 PM
  5. Water pump repair on a 55 Johnson
    By Mike Neels in forum Johnson Evinrude Outboard Archive
    Last Post: 04-24-2003, 08:36 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
