Get instant online access to repair manuals for your Chrysler / Force outboard. Online Manuals
ChryslerForce
Order printed Chrysler / Force service manuals — shipped to your door! Printed Manuals
ChryslerForce
Use engine diagrams to find & order parts for your Chrysler / Force engine. Engine Diagrams
ChryslerForce
Results 1 to 7 of 7
  1. #1
    Join Date
    May 2003
    Location
    , Mich, U.S.
    Posts
    3
    Default Ok I was in a hurry to winter
    Ok I was in a hurry to winterize my boat and I pulled the wrong screw out. I pulled out the shifter pivot pin and what ever it held in place fell and now it wont line back up. I can move the shifter back and forth and get pin back in but it doesnt seem aligned cuz It wont allow for the prop to turn while in neutral. IS there a way to align this back up with out having to remove the lower unit? Thanks
  2. #2
    James Fegan's Avatar
    James Fegan Guest
    Default Sorry but it will have to be
    Sorry but it will have to be pulled apart to fix.
  3. #3
    Join Date
    May 2003
    Location
    , Mich, U.S.
    Posts
    3
    Default Will I have to drop the whole
    Will I have to drop the whole lower unit or just yank out the prop shaft and align that way? Thanks
  4. #4
    Join Date
    May 2001
    Posts
    1,678
    Default " Rocco, You might be able
    " Rocco,
    You might be able to align the coupling by pulling the prop shaft and reaching in with some sort of tool, but you might be able to do this without going that far. You might get the holes in the coupling to line up with the screw hole in the casing. It would have to be in forward, and it might help to disconnect the lower shift rod so you can manipulate the shift rod a bit. Use an awl to reach through the screw hole so you can position the coupling.
    Tony "
  5. #5
    Join Date
    May 2003
    Location
    , Mich, U.S.
    Posts
    3
    Default Tony...you rock I need to ge
    Tony...you rock
    I need to get this thing working. Ive had at least 3 good days were I could of slayed the crappies. Thanks for all the help.
  6. #6
    poker casino246's Avatar
    poker casino246 Guest
    Default "***** ****** [url=""]***** 38
    "***** ****** ***** 384"
  7. #7
    poker casino468's Avatar
    poker casino468 Guest
    Default "***** ****** [url=""]***** 62
    "***** ****** ***** 626"
Similar Threads
  1. 1989 FORCE 125 HP CHOKE PROBLEMS
    By ryasaved in forum Chrysler Force Outboard Forum
    Last Post: 08-17-2009, 11:54 PM
  2. b83 Force 125 steering problem pivot pin
    By wes in forum Chrysler Force Outboard Archive
    Last Post: 05-29-2007, 09:29 PM
  3. 1989 Baylinerwith 85hp force problems
    By wildcat138 in forum Chrysler Force Outboard Archive
    Last Post: 04-10-2007, 09:30 PM
  4. 1989 yamaha 8 hp shifter
    By aaron Croom in forum Yamaha Outboard Archive
    Last Post: 07-23-2006, 12:44 AM
  5. 1989 Force 85 HP shifting problems
    By Dave Murphy in forum Chrysler Force Outboard Archive
    Last Post: 08-05-2003, 10:48 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
