Am i correct in my assumption
Am i correct in my assumption that you can not disconnect the VRO. I am making this assumption based on the fuel is sprayed directly into the cylinder therefore the oil can't be in the fuel because it would bypass the lower end bearings. The oil must be injected directly into the crank case and be carried into the cylinder by the air intake.
If you mixed the oil with the gas no oil would get to the crank bearings.
