Results 1 to 4 of 4
    Daniel Snyer's Avatar
    Daniel Snyer Guest
    Default I just puschased a 1980 Ski N
    I just puschased a 1980 Ski Nautique. I was wondering if the 351 in it is a Windsor or what? I contacted Pleasurecraft Engine Group and gave them the serial and model numbers. They said it is a plain 351 RH engine. How do I identify the engine when ordering parts. The seller said it was a cleveland. I believe they stop manufacturing cleveland's in 1972. Correct Craft verified that the engine is the original engine in the boat.
    croozertoo's Avatar
    croozertoo Guest
    Default "Dan, look for the casting I
    "Dan, look for the casting ID numbers on the block and heads, then search the web for Ford V8 reference code lists. There are plenty of sites that can identify your block and heads. Not sure exactly where the numbers are on the castings, but they should be easy to find. On heads, they're normally under the valve covers. Odds are that it's a Windsor.
    Poopiepantz's Avatar
    Poopiepantz Guest
    Default Looks like Windsor. Last Cle
    Looks like Windsor. Last Cleveland was 1974 with a deck height of 9.206 inch. Windsor deck height is 9.503 inch.
    Feb 2009
    Castlewellan, County Down, uk
    Default need help/// have a 351 win
    need help/// have a 351 windsor out of a mustang that i nowhave in an 83 ford pu.. something puzzles me; it has 2 oil dip sticks..one on side and one in front by the water pump. was this stock for a particular model or a add on.? it has rotary module distributor ignition instead of older points system...also anybody got an idea when engine made?
  1. Identifying a Crusader engine
    By coley4 in forum Crusader Marine Archive
    Last Post: 05-18-2009, 10:15 AM
  2. Help identifying my engine
    By rstroh01 in forum Volvo Penta Gas Archive
    Last Post: 07-09-2008, 06:35 PM
  3. Identifying my engine
    By mrtmaag in forum Mercruiser Sterndrive Archive
    Last Post: 12-08-2006, 11:50 AM
    By r66 in forum Other Gas Inboard Mfgs IO and Sterndrive Questions
    Last Post: 05-21-2006, 01:03 PM
  5. Identifying year of engine
    By marcel in forum Outboard motors archive 2000-2004
    Last Post: 04-11-2001, 12:08 AM
