Results 1 to 2 of 2
  1. #1
    E.Albanesi's Avatar
    E.Albanesi Guest
    Default " I own a 28ft. pacemaker w/tw
    " I own a 28ft. pacemaker w/twin chrysler 318s,I just installed all new manifolds & risers,new impellers in the raw water pump. At 1700 rpm it stays at 155, but give it a little throttle and its up to 195 and climbing.Im getting water through all hoses, can someone come up with an answer? "
  2. #2
    Wade Lovell's Avatar
    Wade Lovell Guest
    Default " When I had that problem on m
    " When I had that problem on my 31' Uniflite, also with twin Chrysler LM318s, I found some blockage in the hose to cool the transmissions. That helped some but I ended up rebuilding one heat exchanger and replacing the second with a two pass heat exchanger. "
Similar Threads
  1. Chrysler 360 overheating
    By brandoon in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 07-21-2009, 01:23 PM
  2. Chrysler M440 overheating
    By sunapeeboater in forum Chrysler Inboard and Sterndrive Archive
    Last Post: 08-03-2007, 06:58 PM
  3. 60hp Chrysler overheating
    By joe thomas in forum Chrysler Force Outboard Archive
    Last Post: 06-06-2007, 09:55 PM
  4. Chrysler 318 overheating
    By E.Albanesi in forum Archive 2002-2006
    Last Post: 06-03-2002, 12:21 AM
  5. Chrysler 318 overheating
    Last Post: 06-11-2001, 07:22 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
