DETROIT DIESEL MARINE ENGINES
A
ABEL FIDALGO
Guest
"QUOTE REQUEST
PLEASE , SE
"QUOTE REQUEST
PLEASE , SEND QUOTE TO:
ABEL FIDALGO
ENTRE RIOS 1955 , QUILMES , BUENOS AIRES , ARGENTINA
TEL/ FAX : 5411 -4224 6111
e-mail : [email protected]
ENGINE MODEL :
We projects to install two Detroit Diesel engines (new or rebuilt) in replacement of old engines CAT D379B. Currently this Tug boat , has problems of stability , caused by the weight of the engines . We needs to install less heavy engines .
What engines would you recommend using ?
We can provide you ,the following information:
Engine currently installed : CAT D379B Max RPM :1500 ,Normal operating speed : 1200 RPM
Twin Disc Gear ,Model Number-MG 527 ,Serial Number- RMIJ 3036 / RMIJ 3217 ,Reduction Ratio- 3.86-1 ,BOM-34934 / 31989
size of the propeller ,diameter : 1350 mm ,step : 1575 ,N° of propeller blades 5
weigh : 300 Kgr
We needs two marine engines (new or rebuilt )with marine gears ( 500 hp )
Please , provide the following information about the recommended engine :
cost , weigh , size and fuel consumption.
Best regards
Abel fidalgo
QTY
PART N°
DESCRIPTION
UNIT PRICE
WEIGHT"
I have a set of detroit diese
I have a set of detroit diesel MTU marine engines for sale low hr aplication is continious rated 800 bhp @ 1800 rpm you can look at the same engines at detroitdiesel.com they are 12 cyl 2000 series
