L
Luc Vinet
Guest
" I have big problem to make t
" I have big problem to make that old engine run good. The spark plug are new, the carburetor is clean, the gap on the points is good (.020"), I also polish them with a 600 grid paper ta see if the engine would run better. Actually what the engine does is that at high speed it is running perfectly, Then, when I slow down , it goes good till the handle is just pass the start mark and when i go on the oter side of the start mark, it goes good for a short period then it start to misfire and seems to run on one cylinder. If I put the engine at full speed, it will pick up and fire good on both cylinder. I would like to know if this could be due to the points, condenser or coil. Is there a way to test does systems. "
