" Hi,
Well, I am working on
" Hi,
Well, I am working on getting the port cylinder head off but running into a few problems. One head bolt (screw) came off with very little effort. Three head bolts on the opposite side of the "loose one" broke off. One broke with little effort and one broke with great effort and one was part way out and failed. Also, there appears to be a white powered on all the head bolt which leaves a small amount of white dust. There is a white band all around the cylinder at the head gasket. This motor is used on salt water. Although I have not yet removed the cylinder head I am beginning to think that it is time just to pull of the entire powerhead off and disasemble.
Any tricks that you know of for the broken bolts problem? I was thinking that if I could remove the heads then I would try penetrating fluid, bees wax, a bit of heat, and vice grips to remove the bolts. But they are really really tight. The bolts that I was able to remove required a great deal of force. Do you think I will be able to remove the heads with the broken studs still in place?
Thanks again,
Tom "
" Hi,
Thanks again,
Tom "
