dansera
"Hi all,
Yesterday I had the
"Hi all,
Yesterday I had the first opportunity to install the HotSpark electronic ignition unit. I did this, following the instructions supplied, to the letter. The magnet disc was a perfect fit and seated all the way down without effort; New eyelet terminations were crimped on to the wires from the HotSpark to match the studs on the distributor. The wires were connected as instructed i.e. red to +ve (15) and black to -ve (1), The distributor primary resistance was measured at 3.4ohms and the voltage at the distributor +ve terminal was measured at 10.1volts. The engine static timing was set properly. However despite all this the engine refused to fire up. I rotated the distributor to various positions but the engine would still not start. Then I removed a plug, earthed it to the block, and on cranking noticed that there was no spark at all. This was the same for all cylinders. Plugs, leads, distributor cap and rotor arm are all brand new OEM parts and to correct spec. I am now suspecting that the HotSpark unit may be faulty ( I have seen a posting in marine engine.com discussion board describing a similar situation, hence my conclusion that the unit may be faulty). Please note also that when I removed the condensor I unplugged the violet wire coming from the wiring harness and left it on the side. The HotSpark was connected directly to the coil as already indicated and the polarity was never reversed.
May I have your feedback on this please?
Lawrence"
Yesterday I had the
"Hi all,
Lawrence"
