T
Thom Hans
Guest
" Hi
I have a 82 johnson 115
" Hi
I have a 82 johnson 115 v4 I just found 75 psi on all cylinders except #1 which has about 5 psi. I am a competent auto mechanic, How hard is it to pull the pwerhead and rebuild the motor? Should I bore all cylinders or just the bad one? How do I tell if the bearings are good or bad? Is it worth it? I really would rather spend $500 to $750 rebuilding this motor than buying another used (and abused) motor for $1000 to $2000. Is this a correct way of thinking? "
" Hi
