1965 90 HP Johnson replacement parts
jimg984
need info for a source to get
need info for a source to get parts for this motor
at this point i only need a carb kit...
this the old 4 barrell carb
"James, Carb kits are usually
"James, Carb kits are usually one of the parts still available from the Johnnyrude Dealer. You can also try Sierra"
Sierra does not appear to have
Sierra does not appear to have a kit for that carburetor.It was only used in 64/65/66/67/68.See a JOHNSON dealer.What is the reason for needing the kit??Carburetors rarely are the cause of poor engine performance.
think the floats needs adjustm
think the floats needs adjustment could need new needles and seat. the gaskets will tear for sure............buld dont wanna pump up tight and then hard startin as if flooded
