M
mmadden16
Guest
"I've got a Sears Ted Will
"I've got a Sears Ted Williams outboard with an air cooled 2 cycle Tecumseh that I'm trying to repair for a friend. The motor has been sitting for some time & the gas tank (gravity feed similar to your typical lawn mower) must have been rusted prior to his purchase of the motor. The motor has been converted to a romote tank, which doesnt seam right since their is no fuel pump on the motor. I started by cleaning the carb, changing the spark plug, checking compresion (120 psi) and cleaning & gaping the points to .020. The motor runs but doesn't seam to fire on every stroke, maybe every other or every third. It also runs the same with no response to jet adjustment unless they are completely closed or almost wide open. I've tried swaping carbs & it runs the same with both. I've checked the flywheel key & it isn't damaged. It doesn't seam to lean out like a bad crank seal would indicate. I'm going to try putting a timing light on it to see if it is firing on every stroke & go from there. Does anyone know if there is any timing marks hidden on these flywheels and/or does anyone have any other troubleshooting ideas????? I'd appreciate any help I could get. Thanks!!!"
