I have 1996 Johnson J90ELEDR w
I have 1996 Johnson J90ELEDR when standing at back of motor left bank lower cyl.I think it is #2 piston when I pull plug to check it it seems to have traces of water on it also the upper exhaust port on left side when running slow builds up a grey mixture of oil substance the right exhaust port looks fine that one piston reads about 10 points lower than upper is is it possable the o-ring is faulty?? I am going to pull head and look at that side. motor runs fine at all speeds But I am worried of why that milky oil substance in exhaust port when running slow. any comment on what I should look for Thank you
