N
NWBoater
Guest
"I'm hoping eventually to
"I'm hoping eventually to get this boat running the way it should. So far we have rebuilt the Solex's, replaced the head gasket (good compression),adjusted valves three times,new pointscondensor, cap and rotor. Checked for prop spin and to see if the exhaust was plugged. It seems to have plenty of power up to about 2500rpm but wont get ontoa a plane. It will only rev to 3700rpm under a load. If its in neutral the engine revs strong over 5000rpm. When we're running at 3700rpm under a load and remove the air filter (spark arrestor) you can see gas splattering up out of the carb throat, both carbs. We have not checked the fuel pump pressure or check valve gas supply line, yet. Nor have the carbs been synched. If you have any ideas or suggestions we would appreciate it. Thanks"
