Is their a way to test an infloor tank for leaks
I have a chaparell 187 with a
I have a chaparell 187 with a merc 470 .I think the infloor tank has a leak The guy I bought it from said it had a leak but he think it was fixed. Is there a way to check a tank for leaks?
"If is is a rigid tank you can
"If is is a rigid tank you can cap the fittings and pressurize it with a radiator tester (4 PSI max.).
It will take some MacGyvering, but this is the best way. DO NOT HOOK A COMPRESSOR TO IT.
If it is a poly tank, you're pretty much screwed, pull it out and fill it with water.
If it was fixed, it's probably not fixed now. There is really no way to properly fix a tank once it goes. Repairs are usually only very temporary."
