"Hello all!
volvo penta bb225
"Hello all!
volvo penta bb225b in a tiara 2700 1984, these are 305 chevy blocks
last season the starboard engine stopped charging but ran strong this season I replased the alternators with arco units and now it doesn't charge unless I excite it and the engine bogs down at 3000 rpm. I have been treating these issues independently because when I excite the alternator the engings reving problem persists. changed the fuel pump, swaped carbs with the port engine, swaped coils, they both have oil leaking under the wire but tested good but have new ones to go in todayas will as new wires already installed new plugs and points.
I am trying to get a clear understanding about the relationship between the alternator failing to excite and the engine not reving. Do these systems share electrical components/connections that could cause these problems? also the batteries are new all seems good and fully charged. Oil preasure guage goes to the middle and doesn't fluxuate with engine, the resistor on alternator called 61 doesn't show continuity so I swapped it with the other, no effect. I checked the distributers advance and all seems to be good,
Well, I know this post is a mess but I hope it conveys that I am at my wits end and could use some help.
Thank you"
volvo penta bb225
"Hello all!
Thank you"
