440 Voltage
gatorboy
"What should my voltage be rea
"What should my voltage be reading?----I checked @ the battery with a meter, @ idle it reads 12.02, with with the blower, lights and radio on it drops to 12.0, still @ idle----@ a fast idle with nothing on it goes up to 12.06 Shouldn't this be above 13?"
"Actually, you want far more v
"Actually, you want far more voltage than that.
Check out the battery charge level chart below:
12.6V = 100%,
12.5V=80%
12.4V=60%
12.3V=40%
12.2V=20%
12.1V=0% DEAD
Since you need about a 1/2 to 1 volt to move amps into a battery, add that much to the above to charge it all the way up.
Jeff"
Well I took the alternator to
Well I took the alternator to be bench tested and it was putting out NOTHING! It's getting rebuilt. Thanks for all the input.
