b83 Johnson 70hp has no throttle in reverse
H
Hitechman94
Guest
"Hello, My 1983 Johnson 70Hp h
"Hello, My 1983 Johnson 70Hp has no throttle response in reverse. It runs out great in forward gear all the way to WOT. However, in reverse gear I can't even pull myself off the bank after parking. It won't rev beyond idle in reverse. Any ideas??? Thanks"
"Lets see, it has two cables f
"Lets see, it has two cables from the control box. One shifts gears, the other works the throttle. It doesn't have a separate throttle cable for reverse. Although I have never heard of this problem, it must logically be a problem in the control box itself. Must have a broken pin, lever, or something that is preventing the throttle cable advancing while in reverse."
