B
Bruce Albert
Guest
"My 1988 engine is getting wor
"My 1988 engine is getting worse, Started running rough at low and WOT and has gotten to the point of not starting. Replaced filters and plugs and just got worse. Now it leaks out gas thru core plugs when I squeeze the priming bulb and spits gas out the top carb.Not even sure I'm getting good spark anymore. It it worth fixing or should I cut my losses.Just spent $100. 2 wks ago for a mechanic to tell me it"s running fine. Any advice?"
