N
nocharge
Guest
"I’ve got an ’88 Mercruise
"I’ve got an ’88 Mercruiser 3.7 Liter. When I run the boat, and switch the batteries off, the motor dies. Even at 2500 rpm, above where the charging system should take over I would think. It has an alternator (I think) that’s a bit foreign to me. I'm a good car mechanic, but new to boats.
It’s not belt driven, but instead amounted right on the crank. It’s got two wires coming from it, which go into the voltage regulator. All the terminals on the regulator look pretty corroded. How do I check the alternator and regulator for proper operation. What voltage should I have where?"
