"Whent out last weekend and fo
"Whent out last weekend and found that when starting the motor i have to pump the throttle quickly to geep the motor indling untill it comes to operating pressure.start up ,throttlr,throttle,throttle,runs and seems to die.startup again ,throttlr,throttle,throttle,slows down and wants to die.I have balanced the carbys,adjusted mixture etc.after comes up to operating temp its is ok but when i put in gear have to be quite and execellate as it wants to die.after a bit of runing it idles fine.to keep from getting this problem if i warm it up using 2500+ rpm this usually gets me over the problem,but i dont want to rev s**t out of it all the time .Any sujections."
