mybabyhimi
well i just got the boat and d
well i just got the boat and don't know the back round i would guess that it has sat for a year or more the engine runs great in gear or on the fast idle out of the water but when in the waterwill run great on fast idle and will sit and idle just find try to put it in gear and it shuts offonly way to get it going is to leave it on fast idle just a little then push it to full throttle after all this it will only go about 7mph what i have done so far is cleaned the carbs new plugs one new plug wire and one new coil pack none of this fixed it the other day i changed the oil in the lower unit old oil was gray and milky looking took the boat out agian and it ran great crused around at 30-35 mph for about ten min's then it slowed back to 7mph on it own and thats all it would do now when i pulled it out of the water there was black oil coming from the prop and from a 1/8" hole just below one of the drain screws don't have a tach but the motor sounds like it running good just not as fast as it sounded at the 30-35mph any help would be great
thanks
Robert
thanks
Robert
