F
flopes
Guest
"'93 Crusader 270 XL FWC.
The fluid in the recovery tank shows full. The coolant level was low in the engine so I topped it off. Went on a 1hr ride at normal cruise speed. Next day, the recovery tank was still at the full mark, but the engine filler neck, under the pressure cap (7psi), was low again.
I suspect the cap is faulty, but want to pressure test the whole system for leaks.
The question is what is the correct pressure to test for and is the cap the right one for this motor.
Thanks for your help,
Frank"
Frank"
