scott_duerring
"I am trying to keep this shor
"I am trying to keep this short and sweet, but I have been going through year long saga of trying to find out why my brand new installed velvet drive tranny rattled and vibrated at idle. First told rough idle issue so had everything possible done to my crusader engine from new plugs, wires, cap, rotor, IAC valve, bench clean injectors, valve job... had tranny pulled and sent to distributor, Marysville Marine, they tested and said tranny good, now I am told that the damper plate appears to be bad... I had bought a new one (heavy duty model) that was installed with the new tranny. Has anyone out there ever gotten or heard of a defective damper plate right out of the box?
What can make a damper plate go bad? I never hit anything or shifted above idle. Is there anything in the lower part of the engine, ie, shaft bearings or such that could be causing this problem?
So much for short and sweet..."
