"My brother just found this mo
"My brother just found this motor in the dump. It looked to be in good shape so I decided to give it a shot. After cleaning the carburetor and changing the plugs, it fires up first pull. That's the good news. The bad news is that it's not pumping any water at all. I removed the 4 bolts on the lower end at the water pump housing, but the lower end only comes down so far. If I try to tug on it, I see the shifter is moving. I also have a 1955 5 HP Viking (Made by OMC) that has the same issue. Has anybody out there changed an impeller on one of these, and do they remember changing the impeller without removing the powerhead?"
