15hp 2stroke clogged exhaust
M
Matt Tomlinson
Guest
"the exhaust on my 15hp yamaha
"the exhaust on my 15hp yamaha is clogged. no exhaust through the prop, all going through the relief ports. how do I clear it?"
"Matt, you may be able to get
"Matt, you may be able to get at it by dropping the lower unit and working up in a very restricted space with minimal results at best.
BUT
The best way to get at it and clean it up would be remove the power head which would then allow you to remove the exhaust plate/tube.
These can get severely carboned up/restriced to way below their normal diameter (somewhere around 1 1/4" I believe).
Once cleaned out (or replaced if it's really bad) you should notice a considerable performance increase.
If you do access it by removing the powerhead, make sure you spend the couple of bucks for replacement gaskets - powerhead and exhaust plate - you can rarely save them and for the price, not worth trying to resuse them..."
