Results 1 to 4 of 4
  1. #1
    Join Date
    Aug 2007
    Location
    Jamestown, Tennessee, USA
    Posts
    2
    Default I have a '73 Johnson Seaho
    I have a '73 Johnson Seahorse 6HP that I just purchased. The motor had not run in 2-3 years. The fuel pump was out so I got one along with a new water pump impeller and installed both. It fired right up but no water came out of the "pee hole" I even reversed the impeller thinking it was in backwards. I NEED HELP!!!!!!! Any suggestions would be greatly appreciated.
  2. #2
    Default "Hi. I had the same problem w
    "Hi.
    I had the same problem with my 1971 6 hp johnson.
    After standing a while, the gasket between impleller-plate and housing had simply gone away with years. I used only gasket seal, and my motor now cooles really good.
    good luck!"
  3. #3
    Join Date
    Aug 2007
    Location
    Posts
    2
    Default Thanks I'll try that.
  4. #4
    Default "I have an Evinrude 7 1/2 hp 1
    "I have an Evinrude 7 1/2 hp 1972 or 73 and it doese not start showing water out of pee hole till it warms up for a few It does not seem to be over heatin and I am Wondering if this is normal as I dont have the original manual ??TIAV my email is ([email protected]}"
Similar Threads
  1. 1973 Johnson 40 hp.. more water problems..grrrr
    By Gorto72 in forum Johnson Evinrude Outboard Forum
    Last Post: 11-14-2010, 04:42 AM
  2. 1973 johnson 85hp problems
    By eyehunter in forum Johnson Evinrude Outboard Forum
    Last Post: 09-02-2010, 05:37 PM
  3. 1973 correct craft LM318 water hose routing for cooling
    By charliemitchell in forum Chrysler Inboard and Sterndrive Archive
    Last Post: 06-05-2008, 12:38 PM
  4. 1973 johnson 40hp workhorse water problems
    By mick bradley in forum Johnson Evinrude Outboard Archive
    Last Post: 09-12-2007, 05:31 PM
  5. 1973 Mercury 1150 115HP cooling system
    By waterman_shooter in forum Mercury Mariner Outboard Archive
    Last Post: 06-09-2007, 04:15 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
