"1st boat... this is from wiki
"1st boat... this is from wikipedia...
http://en.wikipedia.org/wiki/Spark_plug
Spark plug gap
Spark plugs are typically designed to have a spark gap which can be adjusted by the technician installing the spark plug, by the simple mechanism of bending the ground electrode slightly to bring it closer to or further from the center electrode. The somewhat common belief that plugs are properly gapped as delivered in their box from the factory is incorrect, as proved by the fact that the same plug may be specified for several different engines, requiring a different gap for each. A spark plug gap gauge with round wires of precise diameters is used to measure the gap; use of a feeler gauge with flat blades instead of round wires, as is used on distributor points or valve lash, will give erroneous results, due to the shape of spark plug electrodes. The simplest gauges are a collection of keys of various thicknesses which match the desired gaps and the gap is adjusted until the key fits snugly. With current engine technology, universally incorporating solid state ignitions and computerized fuel injection, the gaps used are much larger than in the era of carburetors and breaker point distributors, to the extent that spark plug gauges from that era are much too small for measuring the gaps of current cars.
This adjustment can be fairly critical and if it is maladjusted the engine may run badly, or not at all. A narrow gap may give too small and weak a spark to effectively ignite the fuel-air mixture, while a gap which is too wide may be too wide for a spark to fire at all. Either way, a spark which only intermittently fails to ignite the fuel-air mixture may not be noticeable directly, but will show up as a reduction in the engine's power and fuel efficiency. As the plug ages and the metal of the tip erodes, the gap will tend to widen; therefore experienced mechanics often set the gap on a set of new plugs at the engine manufacturer's minimum recommended gap rather than in the center of the specified acceptable range, to ensure longer life between plug changes. On the other hand, since a larger gap gives a "hotter" or "fatter" spark and more reliable ignition of the fuel-air mixture, and since a new plug with sharp edges on the center electrode will spark more reliably than an older, eroded plug, experienced mechanics also realize that the maximum gap specified by the engine manufacturer is the largest which will spark reliably even with old plugs and will in fact be a bit narrower than necessary to ensure sparking with new plugs; therefore, it is possible to set the plugs to an extremely wide gap for more reliable ignition in high performance applications, at the cost of having to replace and/or regap the plugs much more frequently, as soon as the tip begins to erode."
