Results 1 to 2 of 2
  1. #1
    Perry Taciak's Avatar
    Perry Taciak Guest
    Default "The boat starts fine. The alt
    "The boat starts fine. The alternator puts out 12.3V for about 3 min, when the engine is warms up, it increases to 14.4V and the RPMs drop and stalls. If I turn the lights on RPMs increaes to normal. I was told the alternator checks out fine. When warm, it starts and runs for a short time at idle. If I put it in gear, it runs but seems to have less power, and diesels when shut off"
  2. #2
    Join Date
    May 2007
    Location
    Inverary, Ontario, Canada - The Great White North Eh!
    Posts
    9,127
    Default Bad voltage regulator? causing
    Bad voltage regulator? causing your problems...
    Graham
    A "professional" is someone who gets paid for their work - it doesn't necessarily mean they are good at it :)
Similar Threads
  1. Voltage of the cylinder head of Volvo Penta 140 A gasoline engine
    By Mamij in forum Volvo Penta Gas Engine Forum
    Last Post: 05-11-2010, 10:49 PM
  2. 1990 155HP commercial engine High voltage output
    By jezorek in forum Johnson Evinrude Outboard Archive
    Last Post: 04-20-2009, 07:42 PM
  3. Engine stalls
    By mills41897 in forum Johnson Evinrude Outboard Archive
    Last Post: 06-29-2008, 06:28 PM
  4. Increase power engine dies
    By david_1980 in forum Johnson Evinrude Outboard Archive
    Last Post: 06-14-2008, 09:54 AM
  5. Yamaha WR 450 how can I ccm of engine increase
    By peter in forum Yamaha Outboard Archive
    Last Post: 01-05-2003, 01:55 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
